I'm looking for Quality powered speaker to sit beside my FLEX 6600
I'm looking for Quality powered speaker to sit beside my FLEX 6600, all the good ones are not powered, Has anyone found a nice one yet?
Jim
WU5E
I have a little Bose I use . It is bluetooth and has an auxiliary port that i plug into the flex0
Google this: M-Audio BX5 D3 Crimson 2 way Monitor0
Now you did mention Quality so check out the new Heil PRAS unit which comes with the HPS-5 powered speaker.. see it at Heil’s website https://heilsound.com/amateur-radio-post/coming-soon-the-parametric-receive-audio-system/1
Here is another to consider....work very well for me and "Amazon Choice." Link to my web page with more details. Great sound and for both the radio and PC @ about $400.
http://www.nn4zz.com/FLEX6700.htm#Powered_Speakers_-_AudioEngine_5+
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
https://www.amazon.com/Yamaha-NX-50-Premium-Computer-Speakers/dp/B00MMP7XEW/ref=sr_1_1?s=electronics...
I get great audio off these Yamaha.
I had the Bose, spent $250 on them, but one of the speakers stopped working and they are not serviceable. They are glued!! So you can not open them to check for a burned component or a loose cable.
I am extremely happy with the Yamaha. They sound great, can be powered with 12v from the shack power supply so you don't have to suffer the RFI noise from the wall-wart (the Bose had a very noisy power supply).
They also accept 2 simultaneous inputs. I have them directly connected to the Flex radio and the computer so I can listen to the radio and also get any audio from the computer without having to add more speakers to the desk.
They have a Auto Power Off feature so you don't have to turn them on and off every time you leave the shack. As long as they do not receive signals from either of the 2 inputs they will remain powered off.
They are aesthetically pleasing, have great sound for music and come in different colors to match your decor.
Thanks the M-Audio BX5 D3 Crimson 2 way Monitor is on the way now
I am using the PRAS now, I like it. I also have this speaker which works well. https://www.sweetwater.com/store/detail/Rokit5G3--krk-rokit-5-g3-5-inch-powered-studio-monitor?mrkgc... One of my favorite receive toys it this: http://www.westmountainradio.com/product_info.php?products_id=clr_dsp
I use the West Mountain CLR Speaker as well in the mobile.
Jeff
Jim, I too just got my 6600M and that along with my 6700 are make one heck of a station. I have been using the Bose Companion II Speaker on my 6700 for the past 3 years and thought "why not continue with what has been working great!". I purchased a new pair on eBAY for somewhere around $90 NEW / Unopened Box and as in the 6700 these are fantastic. No issue with RF and plenty of volume.
Good Luck
Richard - N4RWG
I saw Al's setup on his website, did a little research and ordered a pair. Great decision. I made a couple aluminum adapter plates that goes between the speaker and a vesa mount on a couple clamp on monitor mounts. The aluminum plate has a center hole (counter sunk) to mount the speaker and 4 holes in the corners to mount to the vesa. The speakers are about ear high and point directly towards me.
The nice thing about these speakers is that they are dual input. I have my Flex on one input and a KX3 on the other input. Or use one input for your Flex and the other input for computer output.
I'll load a picture on my qrz page shortly. It's too large to post here.
Rich - N5ZC
I prefer my Visio Sound Bar which I have mounted high on the wall complete with remote.0
I use an Anchor AN1000X Powered Monitor (mono).
It might be a bit of overkill, but the mono isn't a problem since any real operating I tend to use the headset anyway.0 -
And a real plus to the Bose Companion 2 speakers is the fact they run on 12v - bonus! No wall wart!0
JBL Control 2P have 35watt amp built-in. Recommended by Bob Heil.0
I have the Audio Engine 2, very nice powered HiFi stereo speakers. you can see them on my QRZ page: https://www.qrz.com/db/K0EOO
Audio Engine here: https://audioengineusa.com/
I have the older #2 but now they have the A2 and P5 powered speakers and many more...
Dennis, k0eoo
I have a pair of the JBL Control 2P speakers which were recommended by Bob Heil. They work very well.
I went with a Pyle Home PCA1 30 watt stereo amp from Amazon $26.08 Prime. This way I can use any regular speakers. I use 2 way Pioneers. No rf issues with type 31 clip ons running 1500 watts.0
I have the Heil HPS-5 and the Heil PRAS unit. What a difference it makes. Glad to hear (no pun intended) that it will work with a Flex Radio. Having the ability to crank up the 2.5k range makes all the difference in the world to hear speech clearly. Not sure why no one else has a 2.5k equalizer adjustment. Most seem to have 2K and 4K, but skip 2.5k.0 -
I used Bose Companion II and they were ok, and were night/day difference compared to any legacy radio with built-in speakers but just didn't have enough output for me. The speakers have to right in front of you and the audio in/out and power had to run across the desk, susceptible to RFI. Running the Bose at full volume isn't the answer as there was zero head room and some distortion was audible. Runing anything at max is never a good idea. So I moved up to the JBL Control 2P powered speakers 35 watts which is much nicer mounted at head level. My hearing has degraded since then, and having to run the JBL's at a higher level when not using headphones.
I did have more RFI with the Bose Companion II as compared to the JBL's, lots of ferrite fixed that but still, JBLs can be mounted where you want them where the computer speakers sit on your desk taking up valuable desk space.
You did mention quality and you have a Flexradio. Don't cheap out on your ears, so my opinion is don't waste your money on good computer speakers, spend a little more on better quality powered speaker such as the JBL, or others mentioned. Actually Bob Heil recommended these JBL's before he came up with his own.
I like the Audioengine A2+ powered speakers. They are attractive, have plenty of volume and sound great. $260
- 310 Community Topics
- 565 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 384 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 8.9K Radios and Accessories
- 106 FLEX-8000 Signature Series
- 886 Maestro
- 49 FlexControl
- 840 Genius Products
- 432 Power Genius XL Amplifier
- 296 Tuner Genius XL
- 112 Antenna Genius
- 263 Shack Infrastructure
- 184 Networking
- 427 Remote Operation (SmartLink)
- 132 Contesting
- 685 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 914 Third-Party Software
