N1MM+ SO2R with 6600M. Only single spectrum window supported?
Andy - KU7T
I am trying to get N1MM+ spectrum windows to work. I can get a single window for Radio1/slice A, but would expect a 2nd window while doing SO2R. Has anyone figured out how to get 2 windows? If not, I an work with N1MM to sort it out... but I wanted to check with others first...
Andy
KU7T
Andy
KU7T
This post should be directed to Tom N1MM and the N1MM programming team. as far as I know, currently only 1 pan adapter is supported.
Andy,
I asked this question not too long ago on the N1MM reflector. Chris is correct. Unless something has changed since I asked the question, only one spectrum window is supported.
Rich - N5ZC
Andy,
Rich - N5ZC
How about WL? Support two slide spectrum windows from 6600m ? Yuri N2TTA0
Just FYI, N1MM+ in SO2R mode does now support 2 spectrum windows for data coming from a Flex running Smart SDR v2. The latest N1MM+ update is needed for it (1.0.7223.0 or later from http://n1mm.hamdocs.com/tiki-list_file_gallery.php?galleryId=15). If you see any issues let me know.
Andy
KU7T
(member of N1MM+ dev team)0 -
Looks good Andy,
Rich - N5ZC
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
