N1MM+ SO2R with 6600M. Only single spectrum window supported?
Andy - KU7T
Andy - KU7T Member ✭✭
edited November 2018 in FLEX-6000 Signature Series
I am trying to get N1MM+ spectrum windows to work. I can get a single window for Radio1/slice A, but would expect a 2nd window while doing SO2R.  Has anyone figured out how to get 2 windows?  If not, I an work with N1MM to sort it out... but I wanted to check with others first...
Andy
KU7T
  • ctate243
    ctate243 Member ✭✭
    edited June 2018
    This post should be directed to Tom N1MM and the N1MM programming team.  as far as I know, currently only 1 pan adapter is supported.
  • Rich - N5ZC
    Rich - N5ZC Member ✭✭✭
    edited June 2018
    Andy,
    I asked this question not too long ago on the N1MM reflector.  Chris is correct.  Unless something has changed since I asked the question, only one spectrum window is supported.
    Rich - N5ZC
  • Rich - N5ZC
    edited June 2018
    Andy,
    Rich - N5ZC
  • N2TTA
    N2TTA Member ✭✭
    How about WL? Support two slide spectrum windows from 6600m ? Yuri N2TTA
  • Andy - KU7T
    edited September 2018
    Just FYI, N1MM+ in SO2R mode does now support 2 spectrum windows for data coming from a Flex running Smart SDR v2. The latest N1MM+ update is needed for it (1.0.7223.0 or later from http://n1mm.hamdocs.com/tiki-list_file_gallery.php?galleryId=15).  If you see any issues let me know.
    Andy
    KU7T
    (member of N1MM+ dev team)
  • Rich - N5ZC
    edited July 2018
    Looks good Andy,
    Rich - N5ZC
