A cost effective Web Relay control
Mike-VA3MW
I wanted to share a 4 port cost effective Web Relay Switch. This is a subset of the one I use on my remote base (I use 16 relays). While there are many other way, I like this software as it allows me to start to build out the RemoteQTH server as you build up your station.
This is a picture of my test setup. When done, all you need is the power cord, the network cable and any devices you wish to turn on or off to be wired in.
Regarding the Remote RCA connector:
This RCA connector is provided for remote power-on functionality. When the RemotePower ON feature is enabled, shorting this input to ground will activate the radio - openingthis connector will disable power on the radio. Refer to the SmartSDR documentation forinformation on how to configure this input. (Note: 3.3VDC Max Input.)
The parts required are:
After that, let's assume you want to add some control for AC Power devices. I found this on Amazon which is the least expensive power switch I could find, called the IoT Relay for less than $30 each.
Once you have all that wired up, this is the One of the Web Views you can get and it works well from a Mobile Device:
There are many other ways to get this done, but this one is one of my favourites and does not require any wire wrapping, soldering on special jumpers.
Mike va3mw
- Raspberry PI with power supply and SD card
- An RCA cable to plug into the back of your 6000 series (you can cut up an old Stereo cable off the HiFi
). - 4 Relay Shield KS0212 from http://www.keyestudio.com/keyestudio-rpi-4-channel-relay-shield.html
- Software from RemoteQTH and their RemoteQTH Server
- Order the RPI if you don't have one already
- Order the KS0212 for $8.99
- Find and RCA cable that has the RCA connector on one end to plug into the radio and bare wires on the other end to wire up to the KS0212
- Build the RPI server by downloading the image from RemotQTH and booting your RPI (directions are on their website on how to build and image and get up and running. Their image is a complete Raspian install.
- Login into their control panel and you want to configure their relays numbered 1, 5, 17 and 24. This will be relay 1, 2, 3 and 4 on the KS0212 that you have plugged into the RPI.
Mike va3mw
2
Excellent post. Thanks. You are paying a lot less than the ones I use.
I control the 6700 RELAY ON connection and also use three of the IoT Relays for other gear. They are excellent for 120 VAC switching.
I have been using these two remote relays, which are more pricey:
Webswitch 1216H http://www.remoterig.com/wp/?page_id=166
RelayPros Web Relay 4-Channel 20-Amp ProXRZADR420PROXR_WEB-I http://relaypros.com/Relay/Device/ZADR420PROXR_WEB-I
RelayPros RS232 Controller 4-Channel 10-Amp ProXR LiteR410PL_ZRS http://relaypros.com/Relay/Device/R410PL_ZRS
If anyone is interested in the RelayPro versions, I have MATLAB classdefs to control them. MATLAB has an inexpensive home edition for $149. I use it extensively in my amateur radio projects.
73/gus
I had a bunch ask me about this during Dayton, so I just wanted to bump this up. I used this to replace my remoterig equipment as it was more cost effective.0
For those experimenters, I just found this on Banggood that might be worth trying. It is a web based switch that you can use to soft power off your 6000 series radio.
https://www.banggood.com/ESP8266-5V-WiFi-Relay-Module-Internet-Of-Things-Smart-Home-Phone-APP-Remote...
They even have a dual relay one
https://www.banggood.com/5V-ESP8266-Dual-WiFi-Relay-Module-Internet-Of-Things-Smart-Home-Mobile-APP-...
Check these out on Amazon:
WiFi Smart Power ****
- cheap - around $30.00
- 4 Individually remote switched AC Outlet
- 4 USB Outlets - remotely switched together
There are much more expensive versions but likely use the same internal parts..
Working fine.. I'm using an Android App for control
US
https://www.amazon.com/Conico-Protector-Outlets-Compatible-Controlled/dp/B074SFQDN5/ref=sr_1_3?ie=UTF8&qid=1527752246&sr=8-3&keywords=WiFi+Smart+Power+****+Surge+Protector
Canada
https://www.amazon.ca/gp/product/B079X2CRK9/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Need a Web Relay? Take a look at www.controlbyweb.com Highly recommended! I bought mine used on eBay.0
The KMTronics ones are of great value as well. I have used this one.
https://www.ebay.com/itm/KMTronic-LAN-Ethernet-IP-8-channels-Relay-board-WEB-BOX/281238587151?hash=i...
Mike va3mw
Hey Michael do you check the panafall to see if these devices emit RF? I imagine yes but thought I would ask.0
I did and I didn't hear the KMTronics one. They will also work directly with PSTRotatorAZ.0
Anyone come up with a coax relay , that is reasonable to remotely turn them on and off, to protect from lightning ?0
Hi Kevin
Most coax relays will work with web switches. If you are searching on eBay, DowKey is the gold standard. This one looks cool https://www.ebay.com/itm/Remote-Controled-Android-OS-MS-S4-WiFi-smart-ANTENNA-COAXIAL-SWITCH-2-KW-PE...
Of course we also have our great line by 4O3A will do the same. Much better quality.
Mike,
You might want to update your post to specify that the Raspberry Pi 3 B+ is NOT supported by the remote QTH server software download.
Dan
I see that, but I will leave that message for Dan's team to get out.
Mike,
I am a total newbie when it comes to Raspberry PI. I got the remote QTH disk image successfully written to the micro SD card. When the Pi boots all I get is Linux commands ending in a login prompt.
when I try my callsign with the default password of 1234 all I get is incorrect login prompt.
I am stumped.
Anything you can help with on this?
Dan
I use the Insteon home automation switches. They have an app that allows remote control and
can automate lights in your house .
This is their relay switch that can directly interface with the RCA plug on the flex
https://www.insteon.com/io-module/
You do need one Hub in your house but all the command and control is done over the
electric household 110V wiring
https://www.insteon.com/insteon-hub/
The first time you go to the IP address and log in with “yourcall” then password “1234”. Once you do that, then you go in and change the user name and put your callsign or what ever you want then a new password.0
Michael, I have some curious ( maybe far fetched ) questions ... LOL Currently I'm using the Denkovi 8 relay USB unit hooked to an Ameritron RCS-10 Antenna switch.( cheap route ) I also use the c232hm-edhsl-0 for the Amp to track the radio band BCD data. Do you see in near future that Flex may bring out such a simple PCB as Denkovi, & have like 16 relays, 8 for Antenna switching & the other 8 for like Amp AC pwr control .. etc... I suppose the PCB would also have to have Network connection to Turn on the Flex radio First... Not sure if this has any feasibility or not.... Your thoughts on the ideal all-in-one unit ......OH... I forgot to ask... Is the RemoteQth link for security or ??0
Hi
At the moment, I don't see it on the radar. That is why we did provide the BCD data port that works well with the Denkovi as you have found out.
Can you rephrase your RemoteQTH question? I am not sure what you are asking.0 -
WEB RELAY QUAD: Added a new Remote PTT using one of the WebRelay Quad ports and now can register my Flex remotely. Using others three ports for Flex Remote on, 220 power to SPE 2K-FA amp via HD relay and SPE Amp on. Realy neat and complete remote relay package.
Great little unit. 73 Russ K5OA2 -
Running SPE from 220VAC - What HD relay did you use
73 Mike
YC-GP-DPDT-6D YuCo Power Relay 12V DC Coil 50Amp 2 Pole DPDT Heavy-Duty
Got from Amazon put in 6 inch by 6 inch plastic electrical box and made up short power cord with 5-20 proper plug for my 220-230 volt outlet with # 8 wire to power panel.
So I use one relay to turn on this relay with 12 volt coil, , one to turn on amp with 12 volts to remote on, one to turn remote on ground to Flex and had the spare now used to give me remote PTT so I can re-register my unit if needed. Had help VE2WU and lost my unit in Smartlink but SmartCat worked and it is 85 miles away!
Most at local electrial supply will work but hard to find the 12 volt dc coil.
Hope it helps Mike.
73, Russ K5OA
I am not using an relay boards but RemoteQTH SW with solid-state relays drived via opto-transistors
Here's one that's directly controllable with USB. It has eight SPDT relays, comes with free software, doesn't require the Raspberry Pi, and costs less than $18.
https://www.amazon.com/gp/product/B07DYNVB38/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
All it needs is a 5 V power supply and a USB connection to a Win 7 computer. The app only only works on Win 7, but you can address it through programming under Win 8.1 or 10.
Moving this to the SmartLink conversation0
This thread has been interesting reading--using the now unavailable USB Knacro 8-relay bank, I built a little enclosure that is set to open the Remote On switch, to open the 12v power supply to my 6400, and to open the 240v line to my amplifier. I can also close the PTT line on the 6400. It doesn't look like there is any RF emanating from the aluminum enclosure, at least in the HF bands. The device is controlled by an executable file running under Win 10.
I have been using an IP Power Switch 9258 (http://www.aviosys.com/9258.html) to remotely power devices at my remote base in Maine including Flex. It has worked great, except when it doesn't. Currently, it is offline. When this happens, I have to wait for a power failure after which it normally comes back online (not unusual in rural Maine). Obviously, I will be looking to put in a more reliable system once the snow melts. The ideas presented here will be a big help.0
IF you have not done so you might look to see if setting up the ping function to reboot will fix your issue.0
I am new to Raspberry Pi as well, and setting this remote control arrangement up for the first time, using the KS0212 relay board. I'd like to package this... any suggestions for selecting an appropriate case (RPi 3)?
Got my new 6400 and SmartLink running yesterday... excited to get all this going!
Steve AK0M0 -
Hi Steve
I was not able to find a commercial case that will fit this arrangement. But, if someone finds one, that would be awesome.
Hi Chip,
I've used a pair of Digital Loggers Inc. (DLI) Web Power Switches (version 4 and 7) for years and neither has ever been inaccessible -- not once. An accessory AC Relay adds additional flexibility for controlling equipment, such as the remote on function for your Flex radio. There have been many positive posts on this community in regarding DLI products, including one in this thread.
https://www.digital-loggers.com/lpc.html
http://www.digital-loggers.com/ac.html
Larry KB1VFU
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 67 SmartSDR+
- 181 SmartSDR for Maestro and M models
- 420 SmartSDR for Mac
- 269 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 29 Aurora
- 230 FLEX-8000 Signature Series
- 930 Maestro
- 908 Genius Products
- 328 Tuner Genius XL
- 120 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 767 Peripherals & Station Integration
- 986 Third-Party Software
