message says the radio is in use then reboots
2»
  • Thomas NE7X
    Thomas NE7X Member ✭✭
    edited March 2018
    The issue only happened to me once so far, I was in receive for over an hour and was just changing bands, from 10 to 15 meters. I do not have a computer connected, not running SmartSDR on a computer. I am using the 6400M stand-alone. I also have a very intensive ground system in the shack, over 20 10 ft copper clad ground rods all cadweld together with 00 wire. As I stated above, the first error was a Maestro error, then after reboot I got the Radio in Use error, followed by a reboot lockup, then a third boot to finally recover.
  • KB4OIF
    KB4OIF Member ✭✭
    edited April 2018
    Anyone heard of a fix for this.  My 6400M is doing it twice a day now.  It's ticket number 6143.
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited April 2018
    I have not seen a new release yet.
    edited April 2019
    I can confirm that I only see this when there is a network failure of some point.  In my case, if my VPN to the remote goes flakey, I get the radio in use message.  That is between the 6300 and a Maestro (not on SmartLink).
    I have yet to see (again, only my personal view) my 6600 and the other Maestro present that message unless I had a power bump in the house.
    Just food for thought.
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    edited April 2018
    Still the same message that M radio guys are getting even disconnected from the network right Michael?
  • KS0CW
    KS0CW Member ✭✭
    edited April 2018
    I haven’t ever seen ‘‘tis behavior on my 6600 and .33 appears to have cleared up periodic random restarts..
  • Thomas NE7X
    edited April 2018
    This happened twice for me, Running a 6400M v2.1.33. Reboot and its clears and comes up ok.
  • Jerry  WA9UKB
    Jerry WA9UKB Member ✭✭
    edited May 2018
    Will this be addressed with the last version 1.11.12 I have even changed to a managed switch signal strength is always all green bars when it happens and has been doing this a least once or twice during the day when it’s on. Using flex 6500 and maestro together. Thanks Jerry,
  • KB4OIF
    KB4OIF Member ✭✭
    edited May 2018
    It is not from the internet connection.  mine has done it twice WITHOUT the cable being connected.
  • Wayne
    Wayne Member ✭✭
    edited June 2018
    You probably should have already updated to version 2.2.8 where any issues I was having were corrected been running perfect since I updated the first day it was offered.
  • William Osborne
    William Osborne Member ✭✭
    edited May 2019
    does anyone know if this issue (6143) has been fixed.  To day my 6600M started randomly rebooting, I am using V-3.0.19 and it has done it 3 times n about 3 hours while listening for E3 on FT8. I am using the front panel client with CAT/DAX only.
    Bill--K5ZQ
  • Jerry  WA9UKB
    edited May 2019
    I still receive this at times on my 6500, and sill on the ver 1 latest build.
  • Eric-KE5DTO
    edited May 2019
    Issue 6143 is marked complete as of v2.4.
