Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
Fast SO2R switching now possible with new 2.2.8
As some already have indicated version 2.2.8 is really an improvement also in the field of SO2R switching. I have only tested it in remote mode (with 4G 30 ms latency) and I can see the difference. Now doubt. So to all CW SO2R Flex users - Christmas seems early this year
Cudos to the Flex team!!
2
- 69 Community Topics
- 1.9K New Ideas
- 120 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 87 SmartSDR for Mac
- 143 SmartSDR for iOS
- 149 SmartSDR CAT
- 68 DAX
- 278 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 556 Maestro
- 14 FlexControl
- 723 FLEX Series (Legacy) Radios
- 150 Power Genius Products
- 117 Power Genius XL Amplifier
- 11 Power Genius Utility
- 22 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 89 Remote Operation (SmartLink)
- 50 Contesting
- 127 Peripherals & Station Integration
- 62 Amateur Radio Interests
- 405 Third-Party Software
Sounds good that Kari. I will try to try some SO2R with my 6700 in the future. Just drive SSB so it's fun to see how it works. Has acquired an Expert 1 kFa now as S & P PA. Just loose some cable and it will be a try. / Johan
This is a little off the subject, but I feel like the folks at Flex are part of the family.
Jim, K6QE
could you provide a list of contesting software, in addition to N1MM, that can support Flex 6000 series in SO2R mode?I am going to learn SO2R mode and any suggestion would be apprecciated.
Thank you very much
From the K1XM web site (http://www.k1xm.org/OTRSP/index.html) it seems they are N1MM, WriteLog and Win-Test
73' Enzo
during the we, as I am too far away from Dayton (HI HI), I developed a small utility that supports OTRSP protocol.
I like very much 5MContest, a russian contest software, that, for what I know, doesn't support OTRSP.
My program simply monitor the active (focused) window switching from Radio 1 to Radio 2 as the operator select the related window. It can also configure audio to listen only to the TX focused window, or it can select Stereo or RevStereo audio mode. Configuration is quite simple: you need to set up the beginning text of each window title and the serial port that supports the OTRSP protocol. Actually you can use it with each rig that supports OTRSP protocol and each contest software that uses a separate window for Radio 1 and Radio 2.
I appreciate a lot the SO2R switching imprevement of 2.2.8 release as well.
Thank you Ria for your great hint.
73' Enzo
iw7dmh
