6400M Skipping the software selection and booting to operation
Ron WD5FUN
Since the last software and firmware update my 6400M is skipping the software selection on each boot up. So Tim it has not been fixed. In fact it wasn't a problem before the update but it is a problem now.
Good morning Ron...check out this post and see if it helps...
https://community.flexradio.com/flexradio/topics/6400m-booted-straight-to-operating-screen-this-morn...
Ron
Thanks Ron, I have read that reply from Tim, but I have upgraded to 2.2.8 and that is when the problem started. So 2.2.8 is causing the problem not fixing it.
Ron
I am not sure what you are considering is the problem. The modus operandi with the new software update is that the rig now boots up directly into operational mode. If you want to regress to an earlier version, you do that via Menu/Radio.
Barry VK2BJ
OK Barry thanks, I reread the change is to 2.2.8 I and see the radio was not suppose to show the version screen. Since it always did go to the selection screen I thought that was what it was suppose to do. Sorry for my misunderstanding.0
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
