6400M Skipping the software selection and booting to operation
Ron WD5FUN
Since the last software and firmware update my 6400M is skipping the software selection on each boot up. So Tim it has not been fixed. In fact it wasn't a problem before the update but it is a problem now.
Good morning Ron...check out this post and see if it helps...
https://community.flexradio.com/flexradio/topics/6400m-booted-straight-to-operating-screen-this-morn...
Ron
Thanks Ron, I have read that reply from Tim, but I have upgraded to 2.2.8 and that is when the problem started. So 2.2.8 is causing the problem not fixing it.
Ron
I am not sure what you are considering is the problem. The modus operandi with the new software update is that the rig now boots up directly into operational mode. If you want to regress to an earlier version, you do that via Menu/Radio.
Barry VK2BJ
OK Barry thanks, I reread the change is to 2.2.8 I and see the radio was not suppose to show the version screen. Since it always did go to the selection screen I thought that was what it was suppose to do. Sorry for my misunderstanding.0
- 246 Community Topics
- 489 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
