Modulation with PC NG
Rick l
I recently purchased a new Flex Radio 6400. I am having difficulty getting my transmit audio from my PC to properly modulate the radio. I am using a mic-headphone which is plugged into the audio out and mic input of the PC. The problem is that in order to get the radio to modulate, like the local microphone does, I need to add 30db of boost in my PC mic recording settings. When I do add the boost the noise is so high that RF is transmitted. I also need to bring the mic gain to 100% on the radio. This is only a problem when using the PC on our LAN side. The mic headphone works well on skype and other recording devices. Does DAX need to be employed here?
Any help will be appreciated TX Rick0
DAX is not involved with PC Audio.
I'd make sure you have the latest sound card drivers installed on your PC as a first step.0 -
Thank you Tim I'll check it out0
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 774 Maestro
- 42 FlexControl
- 729 Genius Products
- 253 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 374 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
