Modulation with PC NG
Rick l
Rick l ✭✭
I recently purchased a new Flex Radio 6400. I am having difficulty getting my transmit audio from my PC to properly modulate the radio. I am using a mic-headphone which is plugged into the audio out and mic input of the PC. The problem is that in order to get the radio to modulate, like the local microphone does, I need to add 30db of boost in my PC mic recording settings. When I do add the boost the noise is so high that RF is transmitted. I also need to bring the mic gain to 100% on the radio. This is only a problem when using the PC on our LAN side.  The mic headphone works well on skype and other recording devices. Does DAX need to be employed here?
Any help will be appreciated   TX    Rick
    Tim - W4TME admin
    edited May 2018
    DAX is not involved with PC Audio.
    I'd make sure you have the latest sound card drivers installed on your PC as a first step.
  • Rick l
    Rick l ✭✭
    edited May 2018
    Thank you Tim I'll check it out
