iOS SmartSDR: Audio balance sliders do nothing?
danparsons
In iOS SmartSDR, I have two slices running. I have Slice A’s balance slider set to far left, and Slice B to far right. Yet I still hear each slice in both ears. I’ve tried various audio setting combinations but nothing changes this behavior. What am I doing incorrectly? Thanks!
Forgot to mention, I’m running this on an iPad Pro, latest iOS / SmartSDR, and using headphones plugged into the iPad.0
Stereo headphone?0
Yes, of course.0
In the settings screen there is a switch to “Allow Stereo”. That must be checked or everything in SSDR-iOS is mono.0
This is one of the settings I tried playing with. Whether its on or off made zero difference unfortunately.0
Hi all, the mono headset thingy is mentioned in the manual.
The thing is, that it is basically an issue with Apple which is caused by the fact that some (not all) headsets are seen as mono-devices as they only have one Microphone.
They behave like they need to for taking a phone call and in that case, it completely switches to mono.
However, some headset (and I guess at least all without a microphone) should not have this issue.
If have just tried again with the original Apple cabled Lightning headset and it works in stereo (of course default-to-speaker:off and allow-stereo:on).
Also the included lightning to analog adapter works this way.
Which headset did you try Dan?
Marcus, DL8MRE
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
