iOS SmartSDR: Audio balance sliders do nothing?
danparsons
In iOS SmartSDR, I have two slices running. I have Slice A’s balance slider set to far left, and Slice B to far right. Yet I still hear each slice in both ears. I’ve tried various audio setting combinations but nothing changes this behavior. What am I doing incorrectly? Thanks!
Forgot to mention, I’m running this on an iPad Pro, latest iOS / SmartSDR, and using headphones plugged into the iPad.0
Stereo headphone?0
Yes, of course.0
In the settings screen there is a switch to “Allow Stereo”. That must be checked or everything in SSDR-iOS is mono.0
This is one of the settings I tried playing with. Whether its on or off made zero difference unfortunately.0
Hi all, the mono headset thingy is mentioned in the manual.
The thing is, that it is basically an issue with Apple which is caused by the fact that some (not all) headsets are seen as mono-devices as they only have one Microphone.
They behave like they need to for taking a phone call and in that case, it completely switches to mono.
However, some headset (and I guess at least all without a microphone) should not have this issue.
If have just tried again with the original Apple cabled Lightning headset and it works in stereo (of course default-to-speaker:off and allow-stereo:on).
Also the included lightning to analog adapter works this way.
Which headset did you try Dan?
Marcus, DL8MRE
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
