mic selected bug?
K5ROX
Please advise if your flex does same.
6600 V2.1.33 win 7
I select "Mic" and transmit audio is fine and level meter functions as should since I have it enabled under settings radio setup phone/cw.
If I select PC the meter no longer works but transmit audio is still fine.
anyone?
I'm working with Flex on a problem on pc input selection that doesn't appear when mic selected but not concerning the meter. An audio problem on receive and have no idea if they are or could be related.......0
When using PC Audio, we make a Windows API call to read the mic level and then report that back on the SMartSDR console. If the API call to your sound card fails, we do not get the data. You may try updating your sound card drivers. It might help. Or not.0
Tim, If "PC" is selected for input audio and a microphone is connected to the "Mic" input and you have transmit audio, it has to be a bug does it not?
My PC has no mic except for wireless headphone and there deffinately off So if "PC" is selected I should have no audio on transmit from a microphone plugged into "Mic" on the back.0
- 197 SmartSDR+
- 110 Aurora
- 322 Shack Infrastructure
- 227 Networking
