restart looses transmit audio
K5ROX
When I shutdown ssdr and disconnect power then restart it I loose transmit audio.
Once this happens if I click the drop down menu to select input source, it was at "Mic" so I select any other then select "Mic" again and I get audio back.
Definitely a bug.
6600 v 2.1.33 Win 7
Not definitely, because if it was, more than one person would be reporting it and I cannot reproduce the behavior as you have described it.
I suspect it is the profile that is loading when you start up that is changing the mic input. If you make modifications to the profile settings and do not save them, then this is the behavior I would expect.
Thanks Tim, ill look into that and I'm sure your right However it is a bug because when mic shows selected and it don't work but you select something else then select mic again and it works.
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
