restart looses transmit audio
K5ROX
When I shutdown ssdr and disconnect power then restart it I loose transmit audio.
Once this happens if I click the drop down menu to select input source, it was at "Mic" so I select any other then select "Mic" again and I get audio back.
Definitely a bug.
6600 v 2.1.33 Win 7
Not definitely, because if it was, more than one person would be reporting it and I cannot reproduce the behavior as you have described it.
I suspect it is the profile that is loading when you start up that is changing the mic input. If you make modifications to the profile settings and do not save them, then this is the behavior I would expect.
Thanks Tim, ill look into that and I'm sure your right However it is a bug because when mic shows selected and it don't work but you select something else then select mic again and it works.
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 161 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 438 Remote Operation (SmartLink)
- 135 Contesting
- 723 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 943 Third-Party Software
