WSJT-X Hamlib Error
Reggie
Hi,
I have SSDR 2.1.33 and WSJT-X 1.8 installed in the Win10 VM using Parallels 13; however, I am getting a Hamlib error when opening the connection to the Flex 6600. I configured WSJT-X with the following setting:
Rig: Kenwood TS-2000
Serial Port: COM4
PTT Method: CAT
Mode: None
Data Bits: 81N I also tried 82N
Split Operations: None
How do I correct this issue?
Reggie
Reggie -
Not sure if this matters in your environment, but Kenwood serial interfaces are usually 4800 baud, 8N2. You didn't mention the baud rate.
73 - David, AG4F0 -
David,
I set those parameters, but I still get the error.
Reggie
That really doesn't make a lot of difference. The FlexVSP driver will dynamically configure the baud, parity and stop bits of the endpoint device (which is why you never set it in CAT)0
OK, one more thought. Look at this post: https://community.flexradio.com/flexradio/topics/time-to-update-the-recommended-wsjt-x-config. It talks about using TCP instead of COM for communications, and gives some examples. A few people mentioned that TCP worked for them where COM did not.0
It could be a configuration issue with running it in your VM0
I endorse this option. It eliminates the virtual serial port layer form the configuration.0
And, you wrote the book on it.
Use the FlexRadio 6xxx rig profile and enter localhost:5002 into the Network Server box. Set PTT to CAT. It works very well and does not tie up a com port.
73 Jay K8CJY0 -
Try a speed of 19200. That worked for me.0
Using TCP nor setting the baud rate to 19200 did not resolve the issue.
Reggie
I don’t use TCP. It crashes and causes WSJT-X to hang in memory after exit requiring you to **** the process to restart. I have no problems using the serial port option. Likely a WSJT/Hamlib issue and not Flex.0
If you’re using a 6600 you need the new WSJT-X. It should work with 1.9-rc3, or the special build from WO2X. But I would really recommend 1.9 as it has the new DXpedition mode and you can take part in the tests.0
That's interesting. I do not have those issues.0
As Ria said, download the latest version of WSJT-x, currently 1.9 rc3. https://physics.princeton.edu/pulsar/k1jt/wsjtx.html Scroll down newr the bottom for the link to latest 1.9 release candidate for Windows. The 1.9 or higher versions support the 6400 and 6600 models. I suggest following the insteuctions on this thread, https://community.flexradio.com/flexradio/topics/i-am-trying-to-get-my-new-6600-working-with-wsjt-x-rx-works-cat-doest?topic-reply-list[settings][filter_by]=all I suggest creating a TCP port 5004 and in WSJT-X for radio IP use 127.0.0.1:5004 Reason is 5002 is reserved for DDUtil and if you use or plan to use DDUtil in the futurw you will have a conflict. Dave wo2x0
All,
Thanks for the assistance. WSJT-X 1.9 rc3 is working. I was reluctant to use this version since it was Beta, but it resolves the Hamlib error.
Reggie
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
