FRStack Version 2.1.30.9 Released - USB Relay, CWX support
Mark_W3II
Member ✭✭✭
USB Relay control feature added. FRStack install includes UsbRelay command line program that is accessed from Run menu item and configured in Global Profile Program Launch list context menu.
CWX Window with Live mode support
Global Profile Program Launch items can be run from Run menu on Main Window.
Global Profile selection is not optional if "menu" option is selected.
New main window tab to control your SPE Amplifier
Radio / Maestro / FRStack Tune disables RCA TX (external), SPE or PGXL amps. Allows HF-AUTO to adjust at tune power level.
Memory option to set Panadapter Bandwidth
Active Slice Frequency Up / Down hotkeys
FM Reverse menu item and active slice hotkey
Slice specific MUTE Toggle Hotkeys
Memory Add DAX option of 'Not Set'
Previous community article announcing SSDR/W 2 compatibility and SmartLink support
https://community.flexradio.com/flexradio/topics/frstack-version-2-1-30-4-released
If you do not have FRStack already installed you can download it at
http://www.mkcmsoftware.com/Flex/Index
2
Mark,
Outstanding! Using Global profiles to change qrg.. Also running CWX for the first time. Working Great...
Don...w2xb
I have a Flex 6400, Palstar HF Auto, and SPE 1.3k-FA . My amp is not showing up in the FRS app
How do I set spe integration up?
Connect your USB control cable between the PC and SPE amp. Configure via View, Options menu, SPE tab. Select control com port for SPE amp in SPE tune features.0
Ah.. Thanks.
Congratulations Mark on ongoing development of this fine peace of software!
Can someone provide details of installation, programming and operation of a relay board, please.
Tom, SP7WT
FRStack's View Menu, Global Profile Program Launch Editor. In the editor right click on the list of programs area. The context menu will display "Add USB Relay" / ON | OFF / COM **** List. You will have to know the COM port the USB relay created. You will need to create an 2 entries, 1 for ON and 1 for OFF. In Windows 10 run window type "device manager". in Device Manager watch the list of com ports as you plug your USB Relay in then out. you will be able to see the COM port come and go. Mine is called "USB-SERIAL CH340".
Any "LCUS - type 1 USB relay module USB intelligent switch control" that is set by sending its COM port the following HEX sequence A00101A2 for ON and A00100A1 for OFF.0 -
Mark, great software. I use it on a daily basis.0
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
