Retain sorting order in memory channels
I would like the Settings>Memory Channels page to retain the prior sorting selections when smartSDR is started.
I like to sort by group, where i have JT, 2M, FSQ set and would like this sort selection saved for future sessions. Currently, the sorting selection is retained only for the current session.
Please consider implementing.
This would be handy with the M radios.
Keep up the great work, Flex is the Best !
This is feature request #52450
I am glad to see this finally has turned into a request. I would like to make a suggestion of something else that needs to be updated for memories.
Currently the Memory select is under settings. I really don't consider memories a "setting" but more of a function which needs quick access just like the Band button. It's the same thing..
I would like to see the Memory selection moved from settings to a button on the left with the other buttons like "Band". Not sub to the Band button but a button at the same level titled "Memory" on the left inserted under the Band button.
I am still on V1 and love it but would gladly upgrade to get this and the sorting of the memories.
What do you think?
Tim, any thoughts.
Harold
W5ZZT
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
