Retain sorting order in memory channels
mdavid01
mdavid01 Member
edited February 2019 in New Ideas
I would like the Settings>Memory Channels page to retain the prior sorting selections when smartSDR is started.
I like to sort by group, where i have JT, 2M, FSQ set and would like this sort selection saved for future sessions. Currently, the sorting selection is retained only for the current session.
1 votes
Open for Comments · Last Updated
  • Paul  KB3ML
    Paul KB3ML Member ✭✭
    edited April 2018
    Please consider implementing.
    This would be handy with the M radios.
    Keep up the great work, Flex is the Best !
    edited April 2018
    This is feature request #5245
  • Harold Rosee
    Harold Rosee Member ✭✭
    I am glad to see this finally has turned into a request.   I would like to make a suggestion of something else that needs to be updated for memories.
    Currently the Memory select is under settings.  I really don't consider memories a "setting" but more of a function which needs quick access just like the Band button.  It's the same thing..
    I would like to see the Memory selection moved from settings to a button on the left with the other buttons like "Band".   Not sub to the Band button but a button at the same level titled "Memory" on the left inserted under the Band button.
    I am still on V1 and love it but would gladly upgrade to get this and the sorting of the memories.
    What do you think?
    Tim, any thoughts.
    Harold
    W5ZZT
