live feed solution
Marc Lalonde
Hi
i look for a solution for live stream Audio from my flex radio , need low latency
any idea ?
VE2PN
any idea ?
VE2PN
Teamspeak0
Remaud works very well if you stream from a PC. Broadwave audio streams from a PC and can be received both on a client PC or a smartphone.
Jim, K6QE
i target more something that is preferably web based
since i have good station i what to supply audio to a local visual blind net operator
so try to have something simple on other end
have try whit RCforb remoteham but it interfere whit my own operation
Hi Marc
What about using using and audio streaming service like Broadcastify, but it is likely too slow.
You could also do a simple VoIP solution like what they do for repeaters or even Echolink. Maybe Astersisk?
Mike0 -
ok Thank all ,will look OBS
Aside for the small latency from the radio itself, most of the latency will be dependent on internet itself.
But generally latency is fairly short. From a few milliseconds to a bit longer. I have experienced up to 1 minuet at times.
I've been using VLC for listening on my Tennessee remote for about 10 years. The latency is long. But for listening it doesn't matter. Works well with my Amazon Echo from the TuneIn skill.
https://www.videolan.org/vlc/index.html
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
