message says the radio is in use then reboots
The issue only happened to me once so far, I was in receive for over an hour and was just changing bands, from 10 to 15 meters. I do not have a computer connected, not running SmartSDR on a computer. I am using the 6400M stand-alone. I also have a very intensive ground system in the shack, over 20 10 ft copper clad ground rods all cadweld together with 00 wire. As I stated above, the first error was a Maestro error, then after reboot I got the Radio in Use error, followed by a reboot lockup, then a third boot to finally recover.
Anyone heard of a fix for this. My 6400M is doing it twice a day now. It's ticket number 6143.
I have not seen a new release yet.0
I can confirm that I only see this when there is a network failure of some point. In my case, if my VPN to the remote goes flakey, I get the radio in use message. That is between the 6300 and a Maestro (not on SmartLink).
I have yet to see (again, only my personal view) my 6600 and the other Maestro present that message unless I had a power bump in the house.
Just food for thought.
Still the same message that M radio guys are getting even disconnected from the network right Michael?
I haven’t ever seen ‘‘tis behavior on my 6600 and .33 appears to have cleared up periodic random restarts..0
This happened twice for me, Running a 6400M v2.1.33. Reboot and its clears and comes up ok.
Will this be addressed with the last version 1.11.12 I have even changed to a managed switch signal strength is always all green bars when it happens and has been doing this a least once or twice during the day when it’s on. Using flex 6500 and maestro together. Thanks Jerry,0
It is not from the internet connection. mine has done it twice WITHOUT the cable being connected.0
You probably should have already updated to version 2.2.8 where any issues I was having were corrected been running perfect since I updated the first day it was offered.0
does anyone know if this issue (6143) has been fixed. To day my 6600M started randomly rebooting, I am using V-3.0.19 and it has done it 3 times n about 3 hours while listening for E3 on FT8. I am using the front panel client with CAT/DAX only.
Bill--K5ZQ0 -
I still receive this at times on my 6500, and sill on the ver 1 latest build.0
Issue 6143 is marked complete as of v2.4.0
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
