Slice receiver tracking
Wayne
Have slice 1 using ant 1 for rcv and ant 2 for xmt and have slice 2 using ant 1 for rcv and ant 1 for xmt. Have slice 1 rcv in left ear and slice 2 rcv in right ear. Both slices on same frequency. Is there a way to make slice 2 freq follow slice 1 freq when i change slice 1 freq if so then all I have to do is press the tx button to choose which ant to xmt on without having to find the freq in slice 1 the have to press A>B to set slice 2 to the same freq then press TX on slice 2. Sure would make operating faster.
Hi Wayne,
If you dont mind using a third party application to do this, Slice Master 6000 has you covered. Just start it up and select the Sync tab then tell slice B to follow slice A. If you also tell slice A to follow slice B, it wont matter which slice you use for tuning. As a bonus, Slice Master will also keep your panadapter displays in sync, so changing the zoom on one will cause a corresponding change in the other. Without a third party application though, I think you are out of luck.
--Don
I don't know if this answers your question or not, but have you tried "diversity" reception with that combination? I have not experimented with it at all yet.0
I have a 6400M not 6600M diversity reception not an option.0
Sorry - I picked up the 6600 from the community you posted it in. Oops!0
- 248 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 773 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 373 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
