Maestro's audio level and compression software meters during CW go full scale.
DV
Have had the Maestro for about a week now. Worked CW today on the local LAN and the new right hand side compression and level meters go nearly full scale when CW is sent (particularly the Dashes.) I can close the meters from the screen, but that just hides what is going on. Microphone control does not function in the CW mode, so I can't turn down the audio level I am seeing on the meter.
Is this normal for Maestro's CW?
K0DV
K0DV
Hi,
I have jut posted a similar question with the same issues.
Did you find the answer ?
Glenn
M1AQO0 -
What version of software are you using? This question is for both Doug and Glenn.0
Hi Tim version 2.0.19, I was using 2.1.30 but it was locking up.
Glenn0 -
Please try 2.1.32 and see if you have the same meter behavior. If so and you need to revert back to 2.0.19, then go ahead and do that.0
Thanks Tim In my post I also asked if there is an adjustment for the signal or a method to check if you’re overdriving ? Thanks Glenn0
If the mic meter peak indicator shows red, you are overdriving it.0
Tim, I am using version 2.0.19. Since I am operating remote from 1600 miles from the Flex 6700, I don't think I should try an upgrade of the software on both ends. There is no one there to do a reset if that is required.
Both the peak meter and the compression meters on the Maestro go into the red. No matter what power setting I use.
Mic level is not power dependent. It is mic gain dependent0
I can appreciate your reservations for not upgrading. However, since the current release is 2.1.32, I an only entering defect reports for the current GA version.0
Tim Not sure if your missing my point. I refer to CW when I asked if it’s possible to overdrive and transmit a distorted signal. How do you check and adjust it or does the software take care of it in order to produce a clean signal ?0
Tim, why should the mic gain impact the CW note?
Glenn - I misunderstood the context of your question. No, you cannot overdrive the radio when using CW.
Doug - It does not.0 -
Thanks Tim, difficult with two strings going on one message haha...0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 746 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
