K9DUR voice keyer can not set up
Trevor-EI2GLB
HI I am trying to get the K9DUR voice keyer set up, no matter what I do I can not get it to accept my PTT serial port settings, it keep saying set up PTT serial port on the program I have created 2 serial PTT ports in smart sdr cat but it wont work with either, can someone help me please,
Trevor
EI2GLB
Trevor
EI2GLB
When you set up a PTT port for SmartSDR Cat make sure it is a PTT protacal, then it should be FlexVSP and what ever come port pick a slice A or what ever one you want it to work with. Then RST only active low and Enable it
Should look like this
The voice Keyer setup should look like this.
Hope that helps.
Jay
W0JAY
Hi Jay looks exactly like that but will not work??
Trevor
EI2GLB0 -
Make sure you have your TX Stream on and the DAX on.
Good luck Trevor
Jay0 -
i have both on only way to get it to work is to disable serial ptt and use vox but every sound in the house is keying the rig, thats not ideal,
Has to be something i am not doing right
Trevor
EI2GLB0 -
A friend had that problem and I dont remember what he did to fix it.
Dry toi delete the port you made and remake it.
Jay0 -
I tried it on my laptop and it worked first time, so I knew it had to be an issue with the PC/ME for some reason smartSDR cat is assigning ports numbers over 100 I found a PTT port that i can't remember what I set it up for and used this in the Voice keyer and it worked,
Its the same as the new port was just a lower number I am unsure why that matters but for me it did,
Thanks for the help
Trevor0 -
No Problem, Hope you can get it to work on the other PC.
Good luck with it. I like using it works well.
Jay
W0JAY0 -
Just for the heck of it also click on the DTR in the set up window.
When SmartSDR is up on your screen the SmartCAT should look like this, of course just the ports you want to use.
My PTT for Voice Keyer is P COM7 Please notice how the "Process" shows (VoiceKeyer)
if not then the problem is at the Voicekeyer setup
73's
Bret
WX7Y
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
