Issue after latest Win 10 update
Wolf
Running Win 10 with Parallels in iMac. After Win 10 upgrade Settings / Radio Setup doesn't work anymore. Same with Profiles / Import/Export Profiles.
Any idea . . . ?
Any idea . . . ?
Oh - there is even more not working anymore.
It shows now a DAX driver error.
So Win 10 did a great job for Christmas . . .0 -
Not one problem with W10 update here !0
Did a complete manually Re-Install of DAX Drivers.
That's working again.
The issue with the Settings and Profiles still exists.
Yup, Windows 10 often requires people to wipe and reinstall programs after updates. Your discovering multiple problems is why I just find the first thing W10 **** up then I Revo it, and reinstall all. I like to troubleshoot things, but its pointless in this case. It's just a feature of Windows 10, and SSDR is not the only program that gets hit by it.
Many people have mentioned Revo'ing uninstall. If you get the time, could you itemized steps you took in Revo? I don't think this method has been "sanctioned" by Flex, but it must be a lot more convenient.
Jim, K6QE
OK - found it . . .
I had an issue with other apps. DLL that were not Microsoft certified caused the problem.
It's now back to normal.
Lessons learned . . . If you use a clean Win 10 PC there is absolutely no issue !
Thanks to all of you and have a great 2018 !0 -
Is a REVO uninstall really equivalent to a manual uninstall / reinstall?0
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
