Issue after latest Win 10 update
Wolf
Wolf Member ✭✭
Running Win 10 with Parallels in iMac. After Win 10 upgrade Settings / Radio Setup doesn't work anymore. Same with  Profiles  / Import/Export Profiles.
Any idea  . . . ?
  • Wolf
    Wolf Member ✭✭
    edited December 2017
    Oh - there is even more not working anymore.
    It shows now a DAX driver error.
    So  Win 10 did a great job for Christmas . . .  ;)
  • Chris DL5NAM
    Chris DL5NAM Member ✭✭✭
    edited April 2020
    Not one problem with W10 update here !
  • Wolf
    Wolf Member ✭✭
    Did a complete manually Re-Install of DAX Drivers.
    That's working again.
    The issue with the Settings and Profiles still exists.
  • Michael Coslo
    Michael Coslo Member ✭✭
    Yup, Windows 10 often requires people to wipe and reinstall programs after updates. Your discovering multiple problems is why I just find the first thing  W10 **** up then I  Revo it, and reinstall all. I like to troubleshoot things, but its pointless in this case. It's just a feature of Windows 10, and SSDR is not the only program that gets hit by it.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    Many people have mentioned Revo'ing uninstall. If you get the time, could you itemized steps you took in Revo? I don't think this method has been "sanctioned" by Flex, but it must be a lot more convenient.
    Jim, K6QE
  • Wolf
    Wolf Member ✭✭
    OK - found it . . .
    I had an issue with other apps. DLL that were not Microsoft certified caused the problem.
    It's now back to normal.
    Lessons learned . . . If you use a clean Win 10 PC there is absolutely no issue !
    Thanks to all of you and have a great 2018 !
  • WA2SQQ
    WA2SQQ Member ✭✭
    Is a REVO uninstall really equivalent to a manual uninstall / reinstall?
