6300 and Tokyo High-power
Jean Drolet
It’s possible to connect my Tokyo hight-power hl-1.5k direct to flex6300 without DDutil
Hello Jean, You will need to set up the amplifier for Kenwood CAT using RS232C. Then you will need to get a FTDI Usb to serial adapter. Plug it in and under the USB cables menu configure this adapter in SmartSDR as a CAT cable. Then you can attach it to your amplifier as you would any kenwood Radio.0
It’s possible without computer i use my maestro on remote0
Yes. The usb cable connects to the radio. No computer is needed. I didn’t mention it but you also need rf in, antenna and ptt cables.0
I have that setup but had to use a Null Modem cable from the USB - RS-232 to the THP amp.0
i coonnect this cable but i dont have reaction between flex6300 and hl-1.5kfx
https://www.amazon.ca/gp/product/B00QUZY4R4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
i order 2 cables ... https://www.amazon.ca/gp/product/B00QUZY4L0/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=10
i connect my cable ... sdr detect i go to the setting usb and i select kenwood on Tokyo.. but dosent work
Are you using a Null Modem cable? The THP requires a Null Modem RS-232 cable. I made a simple adapter using a pair of DB-9 connectors back to back.0
null modem rs232 to my cable ??
https://www.amazon.ca/gp/product/B00QUZY4L0/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=10 -
**** it's the correct cable ?0
You can buy a Null Modem adapter to go between your cable and the THP amp. Just make sure you get the proper male/female connections. As I said earlier, I made one, but they are readily available on Amazon and other Web sites.0
Thank's **** .... all it's ok with null modem adapter...0
For all with tokyo Hi-power HL-1.5KFX
cable: https://www.amazon.ca/gp/product/B00QUZY4L0/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
and null modem adapter : https://www.amazon.ca/Monoprice-101203-Null-Modem-Mini/dp/B001TIP9AS/ref=sr_1_7?s=electronics&ie...
I just did this with a customer and we had to turn on AutoReport on SmartSDR USB/Advanced settings.0
- 375 Community Topics
- 103 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
