What is the offical way to connect a receive antenna (small magnitic loop) to the 6500 series? Have
N0AZZ
What is the offical way to connect a receive antenna (small magnitic loop) to the 6500 series? Have searched but not found a good way to do.
Hook it up to the XVTR port and then select the XVTR port as RX antenna.
73, Andreas, N6NU
XVTR or RXA port. Easy and safe with a BNC connector. You can use either of the UHF ANT connectors, but recommend you not, since it is possible to transmit through them. That’s bad for the loop :-)0
I was gonna say.. -perhaps the RXA or RXB bnc ports.
On a 6500, it would be the RXA BNC port.
You could also use the XVTR port , but the TX/RX switching would probably be cleaner with the RXA.
I agree with others, I wouldn’t recommend using the ANT2 port for a receive only antenna, especially if it has active devices in it.... that is a disaster waiting to happen if you forget and transmit into it. BTW... For those with a 6300, which has no RXA port, 6300 users would need to use the XVTR port for receive only antennas.0 -
To the RX-A port for a 65000
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 766 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
