wsjt x rc2 won't transmit
W5XZ - dan
rc 1 worked fine
have i hosed up the dax channels, or what?
ver 1.8, rc-1 worked great with FT 8..
connecting normally, by dxLabs Commander...0
Maybe your transmit bandwidth is too narrow? Mine is at Low Cut 200 High Cut 25000
thanks, but thats not it...ptt won't even enable..
it's decoding very well, on 160m...but tune button does not put the rig in tx..
much less transmit
config / settings / audio shows
input: dax audio rx 1 (FRS DAX audio )
output: dax audio tx (FRS system dax tx)
radio tab is Dx Lab Suite commander, which is working normally on other
modes...
have shut down and re-started wsjt x 1.8 rc-2 several times...
has Murphy moved in??? again ????
73, w5xz, dan, top band sick-o..
Works OK here. Using CAT for keying. CAT in RC2 settings. P COM9 in SSDR
CAT as ptt,
Ned, K1NJ0 -
with dxLabs Commander? what am i missing?
Only software needed WSJT-X - RC2 and FLEX CAT, DAX, SSDR... Check your CAT and DAX settings. Works fine here. I found that when I upgraded to rc2 it lost my CAT settings and in DAX had to go recheck the TX box. Also under the Frequency tab had to do a refresh. A0
Working here since released0
Did you follow the instructions and reset the frequency tab, in settings?0
CAT is what enables rig control (keying), not DAX. Sounds like DAX is working.0
thanks, guys. found the issue. setttings / radio ptt method...switched from vox to cat, and all is well now...
what a remarkable mode ! 73, w5xz, dan
yes
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 329 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 770 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
