SmartLink Red Meatball After Plenty of Successful Use
Mike W8MM
I have had great happiness using SmartLink with my iOS and Maestro peripherals. Simply wonderful.
Now, all of a sudden, I can't connect from my iPad, iPhone, nor Maestro, even though all of them show my 3 6700's in the chooser accompanied by the SmartLink logo.
When I use TeamViewer to look at my home network PC, I find that when I use the SmartLink Setup button and chose Network Settings, I get the red meatball after pressing "Test".
It used to work just fine. Not so much just now.
I will admit to upgrading the firmware in my Draytek Vigor 3900 router since I last had a green meatball. I checked that UPnP was still operating.
When I use SmartSDR for iOS, all the registration checks, etc., work just fine. Just nothing happens when I chose a radio. Same with Maestro; I see all 3 radios, except I can't connect.
Should I de-register and re-register?
Why did this happen?
After you run the test and get the red meatball, hover over the test. A pop up will appear telling you status, about port 4994 for TCP and 4993 for UDP. If one is working, but not the other, it may give you a clue as where to look.
If it doesn't resolve via the automatic setup, see my earlier post of "two flex" and the manual setup I had to do, because of two radios and a router that doesn't to UPnP. Manual setup is pretty simple and if the auto doesn't work, I'd give that a try.
Good Luck
W8XG - Brent
Did the internal IP address of the radio change?1
Oooh, good question. I'll check!0
YES!!!!
That's the issue. The DHCP reset all the radio IP addresses after the router re-boot to something from outer space.
Tim, you're so smart and so helpful.
Thanks a million!0 -
Just power cyle the radio and UPnP should pick up the change and register it with the SmartLink server1
And I'd setup a DHCP reservation for the radio to prevent this from happening again1
Tim,
Thanks so much for the advice. I'll try to figure out how to set up a DHCP reservation, since apparently I can't set each radio to static IP.0 -
Ooooh, "bind IP to MAC" sounds good!2
Tha is it. DHCP reservations.0
Ooooh Tim ! hah!
Sorry Mike... Guess I just like Floyd, ha!
Recycling the power brought it all back to life after the IP address switch. Goody gumdrop!
Now on to Bond IP to MAC!0 -
How interesting. My Signature Series 6700 is from a different MAC address family than my later two. Change of suppliers of the NIC?0
Bind IP to MAC is apparently Draytek's nomenclature for DHCP Reservation.
Easy peasy to configure.
Hopefully I'm done with radio IP address changes messing me up, now.0 -
Mike, the OUI for the MACs are all TIs1
After a refresh on the router table, I saw that was the case. They originally had no source attribution.0
same issue here Smartlink used to work perfectly but is now RED.
"UPNP & TCP Forwarding both failed! "Radio cannot be accessed using Smartlink"
However internal LAN connection still connects my local computer thru LAN to 6400M.
What broke? Yes, router running UPNP0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
