SmartLink access details for my client app
Mark_WS7M
Member ✭✭✭
I've been writing my own client app for the Flex Radio for quite some time. I'm fairly close to completion but have a few more features I want to put in.
Then along comes SmartLink and 2.x...
I would like to have my app be able to feature the SmartLink login/remote access. Is there a process to support this?
Do I have to sign up for something, sign an NDA?, download a special API?
I hope to make this client available to people for a very low price. One feature it will support is both Windows, Mac and Linux (at least that is the plan).
Thanks in advance.
Thanks in advance.
2
I was told that FlexAPI SmartLink information is forthcoming. We just need to patiently wait. 730
The 2.0 API package is available from the web site
http://www.flexradio.com/downloads/flexlib_api_v2-0-17-zip/
This SDK supports Flex 2.0 LAN (direct) connectivity but does not contain sufficient information or code to support SmartLink connectivity at this time.
730 -
Contact devhelp@flexradio.com for assistance.0
There are three new wan*.cs files in the FlexLib_API_v2.0.17 package that clearly relate to SmartLink interface but I can't extract sufficient information from the code alone to work out how to drive it. I understand that a white paper on the matter is WIP.
Hello,
now I have the same question. Do I have to contact devhelp@flexradio.com for assistance?
I need documentation about the following use case:
1- Discover and connect a rig over WAN via SmartLink;
2- Properly handle connection fault and related disconnection/reconnection of the client
3- Properly handle a busy rig over WAN via SmartLink.
Thank you very much
Enzo
P.S.: I signed up again to the FlexADP Program. Other times I did it but, after that, nothing happened. How should I go on?0 -
Mark, What's the status of your app?0
SmartLink is supported in version 2 of FRStack. If you do not have version 2 visit http://mkcmsoftware.com/Flex/Index0
Yes, send a note to devhelp@flexradio.com for details on SmartLink integration.0
- 339 Community Topics
- 580 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 367 SmartSDR API
- 9K Radios and Accessories
- 893 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 702 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
