How does a third-party application, using the Flexlib API, enable the transmition of digital data su
Jim Shaffer
I am able to receive PSK31, I just can't transmit it. I have DAX channel 1 enabled using the DAX control panel. TX is also checked.
What does my Flexlib API application need to do to enable transmission?
Did you establish a PTT via SmartSDRcat?
The answer is that I need to issue the following command to the radio:
"transmit set dax=1"Thanks Eric!
- 197 SmartSDR+
- 110 Aurora
- 322 Shack Infrastructure
- 227 Networking
