How does a third-party application, using the Flexlib API, enable the transmition of digital data su
Jim Shaffer
Jim Shaffer Member ✭✭
I am able to receive PSK31, I just can't transmit it.  I have DAX channel 1 enabled using the DAX control panel.  TX is also checked.
What does my Flexlib API application need to do to enable transmission?
  • Lou
    Lou Member
    edited April 2017
    Did you establish a PTT via SmartSDRcat?
  • Jim Shaffer
    edited June 2017
    The answer is that I need to issue the following command to the radio:
    "transmit set dax=1"
    Thanks Eric!
