Flex 6500 v Flex 6600
dlwarnberg
Is there anyplace I can see a side by side comparison between the Flex 6500 and the new Flex 6600 (non-M version)?
The only reason I'm looking is because I have long wanted the ability of RX A and RX B as well as XVTR A and XVTR B and be able to set two slices one for 70cm (transverter) and one for 2m (transverter) and have the ability to transmit and/or receive on either without switches... and from what I am seeing the 6600 has that ability (well it has the ports)
The other thing I'd like to see is any other differences between the two Radio's.
David
KK4QOE
David
KK4QOE
1.) The 6600 is expected to have slightly better receiver performance. It hasn't been measured so I do not have any hard numbers to share.
2.) The 6600 will have 2 SCUs for diversity reception and for using multiple antennas at the same time. This add RX-B to the 6600.
3.) The 6600 will have higher rejection out of band preselectors (7th order vs 3rd order filters) for the contest bands
4.) The 6600 will have 2 XVTR ports
5.) The 6600 costs less than a 6500
Thank you Tim0
You're very welcome
Tim - does the 6400/6600 units utilize a upgradeable module design, similar to what Elecraft has done with their K3/K3S?
There is modularity built into the 6400/6600 primarily for serviceability and it may be used in the future to deliver optional feature and performance enhancements.
I cannot comment regarding a comparison of one radio's build architecture vs. another. I just don't have enough requisite knowledge of the K3's details to provide an informed answer.0 -
Couple things, on the 6600 back panel I think I see a "REM ON" port, is that to power the unit on and off remotely, i.e. remote on?
And MARS unlock is that still handled by TURF file or some other method?
David0 -
Yes, just like all 6000s
You will need to purchase the extended transmit filter module as the 6400 and 6600 by default will not come with PA filters for out of ham band transmit. Once the module is installed, a TURF file is required. This is referenced in the FAQ that was updated yesterday.0 -
If the 6600 is a better radio than a 6500, then why does a 6500 cost more?
73 Chris AK4SK0 -
I would imagine that SOME of the price savings comes from not needing to include the out-of-band transmit filters that are included in the 6500, as well as chassis changes eliminating the chassis mounted 8-pin Foster and XLR/TRS Mic connectors, or 1/4 inch headphone & keyer paddle jacks. These have already been commented publicly.
I would guess that the rest - i.e. component selection, economies of scale, and other production costs, would likely enter into the calculations. They haven't said anything about this, but it would make perfect sense that 5 years later there would be many ways to make a better rig for less money.
Ken - NM9P1 -
Thanks Ken.0
Don't forget elimination of the OLED display0
And Moore's law
Economies of scale. Flex is a small company manufacturing a high-value product, and it needs to make money to employ people, create new products and stay in business. When volumes are low, prices need to be high.
As a privately held company, they don't need to say anything about their product volume or the amount of money that flows through the company. But notice that Gerald and others have said in the last couple of years that sales volumes have been surprisingly high. Maestro is an example.
I think we are now seeing the effects of economies of scale. When production runs are higher, unit costs are lower, margins per unit can be lower.
Yeah, just a curiosity I had about the price.0
Hi Tim. I know your post was 8 months ago but I pulled it up as part of my research ad to whether I should get a used 6500 or new 6600. I see now that I can get a used 6500 from Flex for $2999.00 vs $3999.00 for a 6600. So for me, new Flex but wanting a high performance transceiver to replace my FTDX3000, do you think I'd be happy with the 6500 saving $1000.00? Pr eould i midd the dual SCU's Thanks Frank WA3RSL0
Holy Cow the 6500 is light years better than the FTDX 3000 if you need to save some money the 6500 will **** your mind!0
My research confirms your comment!0
Depends if you want to use multiple antennas at the same time on same or different bands.
If so, then the 6600 with 2SCU's wins hands down because it gives you full duplex and diversity capability.
FrankP, I own a 6500 and had put a deposit on a trade-up to a 6600, but some things have changed in my world which will delay that about a year....
Which you choose will depend upon what you want to do with the rig.
If you want to do SO2R contesting with the same rig,
or if you would like to monitor widely divergent bands at the same time - like 6 & 160, or 80 & 10,
or if you would benefit from 7th order bandpass filters on the rig,
or if you want to do diversity reception, using two different antennas on the same band to reduce noise...
Then you will want to spend the extra for the 6600.
If NONE of that interests you, then you will still be blown away by the 6500! It is STILL one of the best rigs available, even though it is discontinued!
Ken - NM9P0 -
Thanks guys!0
If you're doing SO2R in a single radio you need the 6600 (or 6700).
Ria
I forgot to add the ability to have two transverters connected and operating at the same time - I.e. 2 Meters and 70 cm full duplex for contesting or satellite operation!0
I will upgrade to the 6600 but probably will be waiting for the fury to die down. Let FRS get caught up some.
I like the feature set in the 6600 personally.
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 397 SmartSDR for Mac
- 260 SmartSDR for iOS
- 247 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 162 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 725 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 944 Third-Party Software
