OK I give.... No RF output.
John Kennon
No RF output 20 meters ssb. Followed setup, even the "click on this icon left bottom corner" press microphone button, while watching the connected Byrd RF meter. No output. Clicked on tune button, I get RF output on watt meter. Radio just came back from factory where it passed was tests. What have I missed in software setup????? Tried from Maestro, same result.
You will get no output without speaking. Tune injects audio so you can "tune" the radio. Try speaking when in SSB mode.
Jim
Try it on CW or TUNE - should see something then.0
Be sure to speak into the mic and raise the mic gain keeping the voice peaks just under "0" dbm in the Level meter.0
Check your mic input selection and ensure you have the correct mic input.
Cal/N3cAL
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 746 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
