OK I give.... No RF output.
John Kennon
No RF output 20 meters ssb. Followed setup, even the "click on this icon left bottom corner" press microphone button, while watching the connected Byrd RF meter. No output. Clicked on tune button, I get RF output on watt meter. Radio just came back from factory where it passed was tests. What have I missed in software setup????? Tried from Maestro, same result.
You will get no output without speaking. Tune injects audio so you can "tune" the radio. Try speaking when in SSB mode.
Jim
Try it on CW or TUNE - should see something then.0
Be sure to speak into the mic and raise the mic gain keeping the voice peaks just under "0" dbm in the Level meter.0
Check your mic input selection and ensure you have the correct mic input.
Cal/N3cAL
- 392 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 266 SmartSDR CAT
- 210 DAX
- 387 SmartSDR API
- 66 Aurora
- 310 FLEX-8000 Signature Series
- 979 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
