OK I give.... No RF output.
John Kennon
John Kennon Member
edited March 2018 in FLEX-6000 Signature Series
No RF output 20 meters ssb. Followed setup, even the "click on this icon left bottom corner" press microphone button, while watching the connected Byrd RF meter. No output. Clicked on tune button, I get RF output on watt meter. Radio just came back from factory where it passed was tests. What have I missed in software setup????? Tried from Maestro, same result.
  • ka7gzr
    ka7gzr Member ✭✭
    edited April 2017
    You will get no output without speaking. Tune injects audio so you can "tune" the radio. Try speaking when in SSB mode.
    Jim
  • Oxford English
    Oxford English Member ✭✭
    edited July 2017
    Try it on CW or TUNE - should see something then.
  • Dudley-WA5QPZ
    Dudley-WA5QPZ Inactive Employee
    edited March 2018
    Be sure to speak into the mic and raise the mic gain keeping the voice peaks just under "0" dbm in the Level meter.
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited April 2017
    Check your mic input selection and ensure you have the correct mic input.
    Cal/N3cAL
