OK I give.... No RF output.
John Kennon
No RF output 20 meters ssb. Followed setup, even the "click on this icon left bottom corner" press microphone button, while watching the connected Byrd RF meter. No output. Clicked on tune button, I get RF output on watt meter. Radio just came back from factory where it passed was tests. What have I missed in software setup????? Tried from Maestro, same result.
You will get no output without speaking. Tune injects audio so you can "tune" the radio. Try speaking when in SSB mode.
Jim
Try it on CW or TUNE - should see something then.0
Be sure to speak into the mic and raise the mic gain keeping the voice peaks just under "0" dbm in the Level meter.0
Check your mic input selection and ensure you have the correct mic input.
Cal/N3cAL
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
- 785 Peripherals & Station Integration
