Is it possible to ssh or telnet into the O.S. running in my 6300?
Gary L. Robinson
I ask this question because I installed a waveform into my 6300 and misspelled the end of the waveform name as wavefor -- leaving the m off the end. Every time I uninstall it, it disappears from the waveform list but after shutting down my 6300 and later turning it on I see it again in the waveform list in the WaveForm Manager. I suspect it is not really uninstalling it because of the letter m I left off of the waveform name hihi
It's not a major deal but is a bit annoying. If I could ssh into the underlying O.S. (which I suspect is not something I can do) then I might be able to manually delete the waveform file.
Alternately, I could do a factory reset and that might take care of the problem but being lazy I would rather not do that especially when it is just a slight nuisance.
---Gary WB8ROL
---Gary WB8ROL
Nope.. not something you can do.0
Thanks Chris, I figured it was worth asking though hihi.0
You do get extensive access via the API though.0
The question needs a little more detailed answer, IMHO.
s Chris indicated you cannot establish a session with the operating system running on the radio.
You can, however, telnet to port 4992 and communicate with the SmartSDR "command channel" by issuing API based commands to subscribe to radio events and manipulate radio resources (create panadapters and slices, tune slices, enable/disable radio features, etc..) and Ria indicated.
And to address your original question, you need to do a factory reset to properly remove waveforms that are not manageable by the usual means.0
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 329 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 771 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
