Which directory do I install Flexlib in?
Gust2
Hi everyone,
I have my Flex but 2 weeks and I'm madly in love with it! :-)
I downloaded 2 utilities from K9DUR this morning which need Flexlib to get them working.
I downloaded Flexlib but now have no clue in which FlexRadio directory I have to put the Flexlib content in.
Your input would be most welcome.
Using SSDR for Windows on the 6300.
Thank you
73, good DX
Gust ON6KE
Thank you
73, good DX
Gust ON6KE
Hi Gust...
Flexlib is usually compiled into a program and not needed as a separate add-on to make a program work. I've never run any of K9DUR's utilities but I'll check them out if you like me know which ones you are trying.
Kev K4VD
Hi Kevin,
thanks for your mail. I downloaded SDRMonitor and MorseKeyer6K.
In the K9DUR user guides Flexlib is mentioned a prerequisite.
It's funny that I have a Flexlib.dll etc. sitting there in SmartSDR v1.10.16 but both SDRMonitor and MorseKeyer6K can't find the 6300 so I'm stuck at the Connect button of these 2 apps.
7
Gust ON6KE
Got it...
The dll files are already installed. I couldn't get to the Flex when I first started up. I had to enable MorseKeyer6K in the windows firewall.
Oddly, I had to delete the MorseKeyer6K entry from the firewall, restart MorseKeyer6K and then select both public and private in the firewall dialog that comes up.
Once I did that, the radio showed up in the chooser and I was able to get into the program.
Kev0 -
Did what you did here on the 2 apps Kev but I'm still stuck, weird it is.
Guess I'll have to send a little mail to K9DUR.
I'm using CWTYPE for the moment, which accepts calls and names, something CW-X on its own can't do just now.
Thanks for your time Kev.
73, good DX
Gust ON6KE
Hi Kev,
don't ask me why but after having booted my PC this morning and something telling me to give the 2 apps another try, I found that all of a sudden MorseKeyer6K found my 6300.
I had no questions raised by the firewall, all I can say is that it works. SDRMonitor on the other hand doesn't.
So I still have to write a little mail to K9DUR.
Talk later Kev.
73, good DX
Gust ON6KE
When all else fails, reboot. Glad you are making progress.
Kev
You're right there! I have Flex Meter v1.1 in the air now replacing SDRMonitor. It works quite nicely and gives also more info.
So all's well here. :-)
Gust ON6KE
Where do you get Flex Meter?0
- 246 Community Topics
- 489 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 223 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
