60 mts.....JT65 ....No Tx?
YV5WZ
I've been looking to 60 mts...
IARU 2 , 2017 Band Plan
60 METERS Frequencies (kHz) BW (Hz) Mode Applications and observations 5351.5 - 5354 500 CW, DM 5354 - 5366 2700 All Modes 5366 – 5366.5 20 CW, DM ACDS
Why my flex doesnt TX?
Thank you
George
YV5WZ / PY3ZZZ
Thank you
George
YV5WZ / PY3ZZZ
I am guessing that if your radio has a USA TURF file that it is programmed to comply with FCC rules. Basically it will only allow transmission in the dead center of the channel per FCC ruling and if you have WSJTX set to "fake it" then it will think the radio is out of band and then tx inhibit.2
George, what does your Region show under the Settings-Radio Setup-Radio tab?
I know that IARU region 2 rules apply for your country, but for the 60m band local
allocations and rules apply and vary widely.0 -
Another tip - be sure your Tx bandwidth is not set too high. It should be no more than about 2.8 kHz -- normal SSB setting. Otherwise Flex thinks you are going to Tx outside the (narrow) allocated band. But it all depends on your national rules -- and what Flex has coded in its "TURF" limits. See https://community.flexradio.com/flexradio/topics/what_is_a_turf_file .2
Thanks Ria....
WSJT-X set to "None"
73's
George
YV5WZ / PY3ZZZ
Hey !! Alex
My Flex follows USA rules.....USA Turf
Best Regards
73's
George0 -
Thanks Martin
I will check ....usually I have 5.0 Khz and DIGU
Best Regards
George0 -
US 60m channels are only 2.8 kHz wide. I suspect you are transmitting outside of the channel bandwidth.1
Yes Tim....that is!... Thank you
- 275 Community Topics
- 517 The Flea Market
- 7.4K Software
- 6K SmartSDR for Windows
- 143 SmartSDR for Maestro and M models
- 345 SmartSDR for Mac
- 247 SmartSDR for iOS
- 228 SmartSDR CAT
- 167 DAX
- 350 SmartSDR API
- 8.7K Radios and Accessories
- 831 Maestro
- 43 FlexControl
- 842 FLEX Series (Legacy) Radios
- 785 Genius Products
- 413 Power Genius XL Amplifier
- 273 Tuner Genius XL
- 99 Antenna Genius
- 236 Shack Infrastructure
- 161 Networking
- 397 Remote Operation (SmartLink)
- 121 Contesting
- 613 Peripherals & Station Integration
- 122 Amateur Radio Interests
- 850 Third-Party Software
