60 mts.....JT65 ....No Tx?
YV5WZ
I've been looking to 60 mts...
IARU 2 , 2017 Band Plan
60 METERS Frequencies (kHz) BW (Hz) Mode Applications and observations 5351.5 - 5354 500 CW, DM 5354 - 5366 2700 All Modes 5366 – 5366.5 20 CW, DM ACDS
Why my flex doesnt TX?
Thank you
George
YV5WZ / PY3ZZZ
Thank you
George
YV5WZ / PY3ZZZ
I am guessing that if your radio has a USA TURF file that it is programmed to comply with FCC rules. Basically it will only allow transmission in the dead center of the channel per FCC ruling and if you have WSJTX set to "fake it" then it will think the radio is out of band and then tx inhibit.2
George, what does your Region show under the Settings-Radio Setup-Radio tab?
I know that IARU region 2 rules apply for your country, but for the 60m band local
allocations and rules apply and vary widely.0 -
Another tip - be sure your Tx bandwidth is not set too high. It should be no more than about 2.8 kHz -- normal SSB setting. Otherwise Flex thinks you are going to Tx outside the (narrow) allocated band. But it all depends on your national rules -- and what Flex has coded in its "TURF" limits. See https://community.flexradio.com/flexradio/topics/what_is_a_turf_file .2
Thanks Ria....
WSJT-X set to "None"
73's
George
YV5WZ / PY3ZZZ
Hey !! Alex
My Flex follows USA rules.....USA Turf
Best Regards
73's
George0 -
Thanks Martin
I will check ....usually I have 5.0 Khz and DIGU
Best Regards
George0 -
US 60m channels are only 2.8 kHz wide. I suspect you are transmitting outside of the channel bandwidth.1
Yes Tim....that is!... Thank you
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
