60 mts.....JT65 ....No Tx?
YV5WZ
YV5WZ Member ✭✭
edited January 2020 in FLEX-6000 Signature Series
I've been looking to 60 mts...
IARU 2 , 2017 Band Plan
60 METERS Frequencies (kHz) BW (Hz) Mode Applications and observations 5351.5 - 5354 500 CW, DM 5354 - 5366 2700 All Modes 5366 – 5366.5 20 CW, DM ACDS
Why my flex doesnt TX?
Thank you
George
YV5WZ / PY3ZZZ
  • Ria
    Ria Member ✭✭✭
    edited December 2019
    I am guessing that if your radio has a USA TURF file that it is programmed to comply with FCC rules. Basically it will only allow transmission in the dead center of the channel per FCC ruling and if you have WSJTX set to "fake it" then it will think the radio is out of band and then tx inhibit.
  • DH2ID
    DH2ID Member ✭✭✭
    George, what does your Region show under the Settings-Radio Setup-Radio tab?
    I know that IARU region 2 rules apply for your country, but for the 60m band local
    allocations and rules apply and vary widely.
  • Martin AA6E
    Martin AA6E Member ✭✭✭
    edited January 2020
    Another tip - be sure your Tx bandwidth is not set too high.  It should be no more than about 2.8 kHz -- normal SSB setting.  Otherwise Flex thinks you are going to Tx outside the (narrow) allocated band.  But it all depends on your national rules -- and what Flex has coded in its "TURF" limits. See https://community.flexradio.com/flexradio/topics/what_is_a_turf_file .
  • YV5WZ
    YV5WZ Member ✭✭
    edited February 2017
    Thanks Ria....
    WSJT-X set to "None"
    73's
    George
    YV5WZ / PY3ZZZ
  • YV5WZ
    YV5WZ Member ✭✭
    Hey !! Alex
    My Flex follows USA rules.....USA Turf
    Best Regards
    73's
    George
  • YV5WZ
    YV5WZ Member ✭✭
    Thanks Martin
    I will check ....usually I have 5.0 Khz  and DIGU
    Best Regards
    George
  • Tim - W4TME
    US 60m channels are only 2.8 kHz wide. I suspect you are transmitting outside of the channel bandwidth.
  • YV5WZ
    YV5WZ Member ✭✭
    Yes Tim....that is!... Thank you
