wireless Headset from KT9D Nice
James Kennedy-WU5E
James Kennedy-WU5E Member ✭✭✭
KT9D jabr Headset works super with my Flex 6500 and got many great audio reports. it's Plug & Play , must be used in VOX  but it's works great. I have a profile with Heil 781 and now a new profile with the JABR headset.
  • KF4HR
    KF4HR Member ✭✭
    edited June 2020
    I assume the wireless transmitter is plugged into the back of your Flex 6500?  Can you manually operate it via manually PTT (MOX)?  A photo would be interesting.
  • James Kennedy-WU5E
    edited February 2017
    it's powered by a wall wart. KT9D will make the cable for your Flex radio. I just tested the range and walk out side dam it was cold at 70 feet the audio broke up a little, it plugs in the 8 pin connector in the front of the radio and my Heil 781 plugs in the balanced connector in the back of the radio. But inside my home perfect at any range inside my home it's great. YOU must use VOX with this headset.
    edited June 2020
  • Duane_AC5AA
    Duane_AC5AA Member ✭✭✭
    edited June 2020
    I'd guess if you're in front of the radio PTT or MOX would work fine!
    edited June 2020
    The Hand written instructions from KT9D say " USE MUST USE VOX"  see the picture for quality
    the conimage
    there is button on the back of the Microphone if you make a sound you don't want on the radio using VOX tap it once and it's kills the microphone tap it again and the microphone is active again.
  • Cliff
    Cliff Member
    Hi James,
    I also have used a Jabra but an older version and what I did to get around the PTT problem was used a cheap 300Mhz wireless Relay got off of the infamous auction site , worked great just connect to the PTT on the rear of the flex or the mic connector, Just need the RX powered up and the remote is battery powered and very small.
    Also used a similar setup in the car with a ic7000 and enabled easy mobile operation.
    Just an idea anyway, Vox is ok but on the road dangerous :)
    The new Jabra looks a bit sleeker than mine,
    Cheers
    Cliff VK2NP
  • Joe Herreweyers
    edited March 2017
    Can someone provide a link or email address so I can investigate the headset further?
    Thanks all,
    Joe N9EMC
  • Mike W9OJ
    Mike W9OJ Member ✭✭
    His QRZ page says :  EMAIL ME Directly  re: WIRELESS HEADSETS
    Lists his email address as blades1947.cb@gmail.com
    73 de Mike W9OJ
  • Norm - W7CK
    Norm - W7CK Member ✭✭
    edited March 2017
    I have the same Jabra headset that I've been using on an Icom.  Works quite well.  I wired it with 1/8" stereo jacks.  I can plug the receive into the speaker out of just about any radio.  I then plug the xmt into the mic input of a Heil adapter for any radio.  Works well and is easy to plug into just about any rig when wired this way.
    Any idea what he is asking for these?
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    He often has an ad on QRZ. A recent one is at http://forums.qrz.com/index.php?threads/wireless-mic-headset.553506/ $100-110 range. 73 Steve K9ZW
