No Sidetone Using N!MM
W1HZ
W1HZ Member
edited November 2017 in FLEX-6000 Signature Series
I'm using N1MM and can hear the sidetone in the earphones but not through the speaker.  I believe the sidetone is generated by SmartSDR and not the radio.  Is there a parameter that should be changed to hear through the speakers or is this not possible?  Thanks!
  • Al K0VM
    Al K0VM Member ✭✭✭
    The sidetone (CW ?) is generated by the radio but it is not passed to the PC over the ethernet connection. Thus if you have speaker/phones attached to the radio you will hear side tone but if your using the Remote audio feature in SSDR to listen through the PC sound system, you will not have sidetone.
    AL, K0VM
  • W1HZ
    W1HZ Member
    edited February 2017
    Al,
    Much thanks for your response.  Now I know what is necessary to hear the sidetone!
    Rick
