No Sidetone Using N!MM
W1HZ
I'm using N1MM and can hear the sidetone in the earphones but not through the speaker. I believe the sidetone is generated by SmartSDR and not the radio. Is there a parameter that should be changed to hear through the speakers or is this not possible? Thanks!
The sidetone (CW ?) is generated by the radio but it is not passed to the PC over the ethernet connection. Thus if you have speaker/phones attached to the radio you will hear side tone but if your using the Remote audio feature in SSDR to listen through the PC sound system, you will not have sidetone.
AL, K0VM
Al,
Much thanks for your response. Now I know what is necessary to hear the sidetone!
Rick0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
