dd-wrt / Softether on ASUS Router?
I was planning to utilize my Raspberry Pi3 to run Softether when it struck me that hacking my router with DD-WRT I might be able to get Softether to run on the router itself and not need its internal OpenVPN. Nor wouldl I need to run Softether on the Pi or my shack desktop.
Has anyone run Softether on their DD-WRT enabled router? If so, how did it run?
I want to run L2TP / IPsec for my iPad and Laptop when on remote.
Thanks for any ideas....
Ken - NM9P
Just curious what issues are you having with OpenVPN?
I can set it up so that the iPad works, or so the Windows laptop works, but I can't find a setup that lets both work without changing configs....(TUN / TAP issues) I may be getting something amiss.0
You'll need one of the latest Kong builds.
Available here:
http://desipro.de/ddwrt/
Tutorial once you have it installed:
http://bouli.ihostfull.com/?i=3
You'll still need to use the server manager GUI, but having it on your border router is nice.0 -
Ken
I have been using SoftEther Server on the same PC that is dedicated to SSDR and most of my ham stuff. It's a circa Nov 2013 i5 and SoftEther seems to add no appreciable/measurable CPU overhead.
AFIK no one has shown that a dedicated VPN on a Router has a higher throughput than SoftEther on a PC. Perhaps the only downside is that you have to port forward to the PC for the VPN rather than have the VPN at the Router/Firewall...
Softether works well with both iOS and Windows clients0 -
Howard, in my opinion the only negative to your approach is that if your PC goes down, you lose everything (yes, I understand the same could be said about the failure of the router, cable modem, radio, etc). The issue is liklihood of failure. Many believe a windows machine to be a failure-prone environment since it is running a lot of software . The lighter the software enviroment, the theory goes, the less the risk.
You pay your money, you take your chance!0 -
Most of my reason is not performance related. Rather, I want a means to get into my home network independent of a windows PC in case that PC is in use or has a problem, or if I even need to reboot it and upon reboot the VPN service errors out, does not start etc.. Also if you have a laptop you'll want to take that away from home sometimes and not tie it up with vpn duty.0
I long ago solved the PC Failure Issue by having everything running on remote controlled power switches that can easily be recycled to reboot busted PC.
I am now using 2 eight port Datalogger brand which also checks the Internet and reboots routers too if we lose Internet
Doesn't cover the situation where your PC becomes **** due to windows updates or similar, or maybe an actual hardware failure such as a bad drive, dead power supply. Having a separate unit at least allows me to continue using the radio.0
Having flashed DD-WRT on few routers in the past. It was easier to use Ria-N2RJ's script to load it up on a raspberry PI. Less expensive and nothing to worry about.0
Howard is this the power **** your talking about? https://www.amazon.com/Web-Power-Switch-Supply-Cord/dp/B01FWORL1Y/ref=sr_1_1?ie=UTF8&qid=1486487...
Yes. I ended up with two of them. One for the router room and one for the radio room Surprisingly the most active one is the router room as I tend to have to rebid modems and routers more than radios when I'm remote0
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 69 SmartSDR+
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 30 Aurora
- 233 FLEX-8000 Signature Series
- 932 Maestro
- 909 Genius Products
- 329 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 447 Remote Operation (SmartLink)
- 771 Peripherals & Station Integration
- 989 Third-Party Software
