dd-wrt / Softether on ASUS Router?
Ken - NM9P
Ken - NM9P Member ✭✭✭
edited June 2020 in Third-Party Software
I am not totally satisfied with the way OpenVPN runs on my ASUS RT-AC66U Router.
I was planning to utilize my Raspberry Pi3 to run Softether when it struck me that hacking my router with DD-WRT I might be able to get Softether to run on the router itself and not need its internal OpenVPN.  Nor wouldl I need to run Softether on the Pi or my shack desktop.
Has anyone run Softether on their DD-WRT enabled router?  If so, how did it run?
I want to run L2TP / IPsec for my iPad and Laptop when on remote.
Thanks for any ideas....
Ken - NM9P
  • David
    David Member ✭✭
    Just curious what issues are you having with OpenVPN?
  • Ken - NM9P
    edited February 2017
    I can set it up so that the iPad works, or so the Windows laptop works,  but I can't find a setup that lets both work without changing configs....(TUN / TAP issues) I may be getting something amiss.
  • Ria
    Ria Member ✭✭✭
    edited November 2019
    You'll need one of the latest Kong builds.
    Available here:
    http://desipro.de/ddwrt/
    Tutorial once you have it installed:
    http://bouli.ihostfull.com/?i=3
    You'll still need to use the server manager GUI, but having it on your border router is nice.
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    Ken
    I have been using SoftEther Server on the same PC that is dedicated to SSDR and most of my ham stuff.  It's a circa Nov 2013 i5 and SoftEther seems to add no appreciable/measurable CPU overhead.
    AFIK no one has shown that a dedicated VPN on a Router has a higher throughput than SoftEther on a PC.   Perhaps the only downside is that you have to port forward to the PC for the VPN rather than have the VPN at the Router/Firewall...
    Softether works well with both iOS and Windows clients
  • Neal_K3NC
    Neal_K3NC Member ✭✭
    Howard, in my opinion the only negative to your approach is that if your PC goes down, you lose everything (yes, I understand the same could be said about the failure of the router, cable modem, radio, etc). The issue is liklihood of failure. Many believe a windows machine to be a failure-prone environment since it is running a lot of software . The lighter the software enviroment, the theory goes, the less the risk.
    You pay your money, you take your chance!
  • Ria
    Ria Member ✭✭✭
    Most of my reason is not performance related. Rather, I want a means to get into my home network independent of a windows PC in case that PC is in use or has a problem, or if I even need to reboot it and upon reboot the VPN service errors out, does not start etc.. Also if you have a laptop you'll want to take that away from home sometimes and not tie it up with vpn duty.
  • KY6LA_Howard
    I long ago solved the PC Failure Issue by having everything running on remote controlled power switches that can easily be recycled to reboot busted PC.
    I am now using 2 eight port Datalogger brand which also checks the Internet and reboots routers too if we lose Internet
  • Ria
    Ria Member ✭✭✭
    Doesn't cover the situation where your PC becomes **** due to windows updates or similar, or maybe an actual hardware failure such as a bad drive, dead power supply. Having a separate unit at least allows me to continue using the radio.
  • John - K3MA
    John - K3MA Member ✭✭
    edited April 2018
    Having flashed DD-WRT on few routers in the past.  It was easier to use Ria-N2RJ's script to load it up on a raspberry PI.  Less expensive and nothing to worry about.
  • Warren Gaspar
    Warren Gaspar Member
  • KY6LA_Howard
    Yes. I ended up with two of them. One for the router room and one for the radio room Surprisingly the most active one is the router room as I tend to have to rebid modems and routers more than radios when I'm remote
