CW in SmartSDR ?
Bill
Maestro has a built-in Winkeyer (hardware keyer).5
That specific capability is not a feature of SmartSDR. Although we have it in our database to investigate how to do it, but CW keying is very sensitive to latency and adding a PC in between the key and the radio will add latency. Today you need to use CWX.1
Hi Bill, Here is some background on the question. It's 3 years old but has some good info about the options. https://community.flexradio.com/flexradio/topics/remote_is_cw_via_a_paddle_in_scope_for_the_remote_enhancement_coming_in_v1_4_and_v2_0 Regards, Al / NN4ZZ0
This isn't in SmartSDR per se, but I am thinking maybe a serial port on an attached PC connected to the CW pin on the HD15 connector in the back, and maybe some software to pipe a serial port across the wire. Latency would still be an issue but I see some others like remoterig and remotehamradio.com (which uses remoterig) doing CW remotely with paddles and such.
I have not tested this concept but until Flex decides that this capability would be something they want to incorporate, this is a theoretical alternate method.0 -
Hi Ria,
Here is an excerpt from the post I referenced above. Steve indicated they plan to implement the key / paddle interface via a USB/Serial port on the device (laptop, etc) and communication with the radio would be via the network. This was back before Maestro so no telling if/when this will happen now.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
SSDR / DAX / CAT/ 6700 - V 1.10.8
Win102 -
I do, Bill using an USB to RS232 dongle, take dtr signal and by a photocoupler connect to pin 4 of accessory connector. Works very well. I use mixW.1
SSDR for iOS CW Capability. I really enjoy using my iPad to operate my flex 6300 remote. SSB is great. However, trying to work CW with the iPad keyboard and CWX is awkward. I would much prefer to be able to use my CW key. Is there any plan to add this feature?1
Tim
I'm curious why CW works fine on the Maestro but latency is an issue on SmartSDR... ? They both should have that issue , should they not ?
Bill0 -
Could support for an external (USB) Winkeyer be added to Smartsdr?
Possibly, it is just a SMOP (https://en.wikipedia.org/wiki/Small_matter_of_programming) ;-)
Not that I know of. Marcus had talked about it here but there was the problem of connecting the device to the iPad.0
Anyone found a way to externally key the Smart SDR software running remotely. Would like to tie it of other cw keying programs. Hank K9LZJ
I came across this thread looking for how I might connect my CW key to my Win10 laptop while using SmartSDR remotely away from my 6400r. I get that without a "keyer" on/by the laptop this is not possible, and that the Maestro pulls this off due to the winkeyer in it. Is there any solution for this as of today (Aug 2020)? I do have a Maestro on order... Andy K7AMB0
Those interested should take a look at the Groups.io group
https://groups.io/g/RemoteKeyerInterface/topic/
And a search for the RKI (remote Keyer Interface a Software Tool)
While it is far from perfect it can and does work
Steve
KG5VK1 -
Hi Steve,
The Link didn't work for me,....I think this is it.
Regards, Al / NN4ZZ
6700 Win10 SSDR V2.4.10
SmartSDR for MAC does support this and I just tried it last night. You can follow this in the SmartSDR for MAC discussion group.
However, just was our engineering team reported, it doesn't work as seamlessly as you wish.
Even on my internal LAN, the CW latency when keying via an RS232 port worked, but was far from very smooth even at less than 20 words/minute. This is not a fault of SmartSDR for MAC but the challenges of LAN communications. I urge others to test on their own network as well.
I am still working on this just to see if is something I can resolve. I might try feeding a WinKeyer into it and see how it goes. However, if you understand how TCP communications work you may start to understand why it is flaky at best.
Just to repeat, this is not a fault of the SmartSDR software.
Mike va3mw
-1 -
Sooo... Are Mike, VA3MW and Bill, VA3QB (OP, above) actually the same person? Or is it just that all VA3 guys look alike? Inquiring minds want to know...
Len, KD0RC
Len,
Knowing them both they are not at all alike, nor do they look alike!
Pierre VE3KTB0 -
Yep, I was joking because the small thumbnail pictures look so much alike. 🙂
Len
Thank you to the community for the information on remote cw via PC which I have read so far.
Obviously further research by me is required to reach a resolution.
Regards.
Chippy0
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
