When would the FreeDV wafeform be updated so that it don"t **** up a Solid State PA and it also can
The DV mode shouldn't "**** up" anything when operated properly. The duty cycle is higher than SSB, so operators must adjust their equipment accordingly.
As for LSB.. the use of USB for digital modes is by convention and shouldn't make a difference between QSO partners.
Neither question really calls for a change to FreeDV or anything from Flex. Good luck & enjoy operating!0 -
Typically FreeDV activity on 40 and lower is using LSB. It may not be the digital "convention," but that's the way it is.0
But not the convention for FreeDV which as a speech mode follows the convention for speech modes on the lower bands, as also do the SSTV enthusiasts. In U.K. The weekly RSGB news is being transmitted on 80m in LSB with nets before and after in LSB.1
It is not the FreeDV mode that has blown up Solid State PA's , but the FRS FreeDV wafeform. This is also confirmed by FRS 's Matt Youngblood, KD5FGE , as a problem that needs a solution. In Europe we are working on 40 and 80 meters in LSB. For both reasons we are working with FreeDV.exe 1.1. That means we have complicated situations with sound cards and assigned audio IN/OUT's.
I use FreeDV with a solid state linear. I have no issues at all, as long as I respect the amp's continuous carrier duty cycle. I have held numerous QSO's with other stateside operators and not seen an issue with the amp.
Larry, W1IZZ
What is the specific issue that causes the amplifiers to "**** up"?0
Free DV flexradio ((wave form) is all usb all bands.
And the downloaded software from the author of freedv is 10meters-30meters usb and 40meters
-160meters is lsb. The standard conventions of usb-lsb.
This was my finding a while back and the flexradio (wave form) can not be changed from all usb to Lsb.
That's my understanding when I messed with it. So not compatible on 40 meters on down.
Understand this is not flexradio software.
If others use flexradio wave forms in usb that's works.
If others use the authors LSB modes that works but not crossed over on the side bands.
Hi Laary,
Normal FreeDV transmission:
FreeDV Wafeform:
No reaction to the SSPA blown up problem so far. No solution to the LSB/USB issue so far.
In the meantime there are more modes in use within FreeDV then 1600.
There is 700B , 700C and 800XA. The FreeDV wafeform starts to be oldbolish.
Is it possible to use just FreeDV with DAX?0
I tried that and could not get the PPT to work.0
Yes You can use FreeDV with DAX as connection between FreeDV and SSDR. But You have to use a headset on the PC instead of the microfoon and speakers from the Flex. That give some restrictions , and also the PTT control is not ideal in that situation.
Yes but I can't get it the PPT to work at all.0
Ah, now I get it. That would be a problem then.0
You have to use the PTT button in FreeDV or the spacebar on the computer.
Perhaps this wil help.
OK Got it to transmit. Thanks for help!!!0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
